Models with Mechanical Key
Unlocking and Turning On System Power
Main switch
  • Use the magnetic tip of the key to open the keyhole shutter.
  • Insert the mechanical key into the keyhole, press it and turn clockwise from “LOCK” to “OFF” position to open the handle bar lock.
  • Turn the key clockwise once again to “ON” position to turn on system power. The key cannot be pulled out now.
Note: Do not turn the key to “OFF” or “LOCK” position, or the power will be shut down and might cause danger.
Turning Off System Power
  • Turn the key counterclockwise from “ON” to “OFF” to turn off system power.
Locking
  • Turn the handle bar to the left end.
  • Press and turn the key counterclockwise from “OFF” to “LOCK”, and the handle bar is locked now.
  • Pull out the key and press the “SHUT” button to close the keyhole shutter.
Opening the Luggage Compartment
Turn the key counterclockwise from “OFF” or “LOCK” position to open the seat.
